Remove instances from a Patterned Pattern
You can pattern an operation and select instances to remove. You can pattern a pattern of operations. You CAN NOT pattern a pattern of operations and select instances to remove. The pattern function should be consistant in all cases.
6 Comments
it would also be good if it would consolidate the tool paths. for example instead of doing the facing, roughing, finishing. for the first part and then move on to the next, it would do all the facing, then all the roughing, then all the finishing.
@Anonymous what software are you using?(Fusion 360, Inventor HSM or HSMWorks?)
HSMworks
@Anonymous
That's already possible.
First option is to machine each pattern instance like you programmed.
Order by operation means it will do each operation in each pattern instance before moving on.
Order by tool same as order by operation only now it does all consecutive operations with one tool.
denis_q
It would bei great to have the 'Keep original' checkbox also for duplication and component patterns.
al.whatmough
Elements of this request have been added.  Since this idea has multiple ideas together, I am marking it as implemented for the elements that have been completed.
-Keep original has been added
-Ordering was already in place.
