I think the headline says it all.
It would be a very big help if you could activate the bypass of the fixtures in operations.
Such a function is actually already available, especially when chamfering.
Since the milling cutter permanently observes the distance from the milling cutter to the next wall of the part.
You can even set the distance from the cutter to the wall.
Couldn't you rebuild the technique behind the chamfer and add it to the other operations to keep the distance to the fixture?
You should also be able to activate it separately for each operation so that it doesn't take unnecessarily longer to calculate for operations where you don't need it at all.
Especially with 5 axis milling it is very annoying to limit the contours when you have strange shapes.
A feedback from the developers would also be nice 🙂
