HSM Beta Testing (English / Deutsch)
Undercutting support for flow strategy
5 REPLIES 5
fonsecr
2694 Views, 5 Replies
We are working on adding undercut support for the flow strategy. If you select an undercut tool HSMWorks will automatically generate undercut toolpath so there is no additional settings required. Beta mode must be enabled otherwise you will only get ordinary non-undercut toolpath.
This feature allows you to machine undercut fillets moving up and down that you would otherwise not be able to easily machine. See attached example. For now you can try it will the lollipop tool type. Slot mills support is not fully ready yet.
This feature will allow you to machine more parts using 3-axis/4-axis CNCs that would otherwise require a full 5-axis CNC.
René Fonseca
Software Architect
5 REPLIES 5
tim_paul
in reply to: fonsecr
Is this up and running with non beta now? Works2014R2.36916?
I've been wanting to do this for awhile.
Nice feature and very welcome. A+
Nice feature. I had this problem with twoside(back) chamfer.
Haven't seen many problems with it, so guess it will not be light years away from going into production release.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Is it possible to add Check Surfaces to Flow?
