HSM Beta Testing (English / Deutsch)
Spun profile for turning
28 REPLIES 28
Message 1 of 29
fonsecr
6772 Views, 28 Replies
In the latest HSMWorks 2014 development release we have added an early preview of the upcoming "Spun Profile" feature.
At the moment the turning strategies will automatically slice the selected part to get the 2D profile to be machined along the ZX plane. However, this only works if you can find an ZX plane where the slice includes the entire "spun" part. If the part is a mill/turn part you might be required to make the profile manually in a sketch.
However, with the new Spun Profile feature you will be able to automate this task. Note that the feature is currently not integrated directly in the turning strategies but must be run separately. Furthermore, arcs support is being added at the moment so far now you will only get lines in the spun profile.
René Fonseca
Software Architect
28 REPLIES 28
Message 2 of 29
fonsecr
in reply to: fonsecr
You could have a part like this.
René Fonseca
Software Architect
Message 3 of 29
fonsecr
The Spun Profile is exposed in beta mode under the Utility menu from the operation manager. This will be changed once the feature is finalized.
René Fonseca
Software Architect
Message 4 of 29
fonsecr
Once you run the Spun Profile command you will see this dialog. Allowing you to enter an appropriate tolerance, rotary axis, and the part to be "spun". Keep the tolerance realistic!
Ignore the "Use smoothing" setting in the picture for now 🙂
René Fonseca
Software Architect
Message 5 of 29
fonsecr
After you click ok the profile will be generated (which can take a while depending on the tolerance and complexity of the part).
The profile will be automatically stored in the SolidWorks feature tree. That is Sketch5 in this case. The Plane1 is plane in which the profile is defined.
You can then use the profile as the model for each strategy. Or you can make a revolved feature from the sketch (this is the recommended). Note that SolidWorks might not like a sketch with many lines in it.
René Fonseca
Software Architect
Message 6 of 29
fonsecr
If all goes well you should get toolpath like this.
René Fonseca
Software Architect
Message 7 of 29
Epic!
This is gonna make turn/milling so much easier/faster!
Good, that's not necessary for turning in general, but possible for hard parts. 8)
We'll have some fun with it tomorrow.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 8 of 29
fonsecr
And finally the obligatory reminder 🙂
Please use the "Send feedback" feature when you find issues with wrong profiles. Thanks.
René Fonseca
Software Architect
Message 9 of 29
I've noticed that the Spun Profile is created on a new plane. I ve checked several part orientations and seems this plane does not necessarly macht X axis reference defined on the Job. Was expecting it to be placed on the XZ "plane" defined by the Job orientation.
Any space for improovement here?
Message 10 of 29
fonsecr
The spun profile command does not know about a particular job so it cannot choose the same X-axis.
The first step is to make the spun profile and then the job so the X-axis will be in the same direction.
Once the spun profile feature is ready it will be integrated into the turning strategies so you dont need the extra step.
René Fonseca
Software Architect
Message 11 of 29
Humm,I can accept that, mainly if you're handling imported parts.
When you got a SolidWorks model, it would make some sense at least to try to match this profile to other planes used to sketch revolve features. But that leads to correct modeling techniques..ok. I can live with that.
Message 12 of 29
fonsecr
We have now moved the Spun Profile feature to the Utility menu in the CommandManager.
And multi-body components/bodies can now be selected.
René Fonseca
Software Architect
Message 13 of 29
fonsecr
In HSMWorks 2014 R2 we have added support for arcs. By default some arcs will be extracted directly from the selected model when possible.
However, you can also now enable "Use smoothing" to fit arcs to the generated profile.
E.g. for a part like this you will get the shown profile with smoothing enabled.
René Fonseca
Software Architect
Message 14 of 29
fonsecr
Arc support has been further improved in the latest development release. Generation performance should also be generally faster. It depends on the part though.
René Fonseca
Software Architect
Message 15 of 29
fonsecr
We fixes a few issues in the latest development release.
René Fonseca
Software Architect
Message 16 of 29
fonsecr
The spun  profile feature got updated in the latest development release. This time we tried to improve the quality of the profile. Something that you will generally see for ID. Noise within the user specified tolerance should be reduced now. But let us know if there are any issues.
René Fonseca
Software Architect
Message 17 of 29
The sketch which it now generates is perfect René, even without smoothing it is allmost always smooth with arcs.
Only problem we have is that a lot of are parts differ form each other only by size, so would like to use the same program, with spun profile now we have a problem since it doesn't adjust to changes in the model. Would it be possible to integrate this in the future?
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 18 of 29
fonsecr
Yes, we are thinking about integrating the spun profile in the job and/or operations to make it fully associative. This wont make it into the next release, though.
René Fonseca
Software Architect
Message 19 of 29
Would be awesome René!
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 20 of 29
fonsecr
The current utility feature wont be removed. So you can keep using this if desired.
René Fonseca
Software Architect
