I installed the latest build from a few days ago, and when trying to start up, I get the FlexNet License Finder menu.
I enter the License Server - not able to work. I enter Port@LicenseServer, does not work. I enter Port@IPAddressofLicenseServer, still no effect.
I rebooted, and this did not fix the problem.
I ran Inventor from a VM I have with it installed, and from there it works (did not do upgrade there - so it is running a version from May).
Any ideas?
Solved by rsalasidis. Go to Solution.
Solved by sales. Go to Solution.
I have a perpetual license wit HSM PRO - and uptodate annual maintenance.
Also it runs from my VM
I reinstalled the HSM PRO update, and it still does not work
@George-Roberts wrote:
Did you take out a subscription with Inventor HSM? Just thinking it may not be eligible to run 😕
Or installed Inventor HSM Pro instead of HSM 'Standard' ?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
No - did HSM Pro
Just to mention - the license server log - never sees the attempt
It sees my VM logging in and out, but not the workstation
@rsalasidis wrote:
No - did HSM Pro
That would sound like a network issue.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Tested - ipconfig reads OK, DHCP, DNS servers are OK
I can access other network resources OK, from say Windows Explorer etc
The only new thing I did was install a new NVDIA card - but Inventor worked after this card was installed, as I tested the responsiveness of the display with it. This was the first install with that card present however.
Also just to make sure, I disabled all other network interfaces (except the one that is the primary), and even moved my HyperV Ethernet connection to be shared by this primary one - that way there is no way that it is trying to connect via the wrong adapter
I uninstalled everything (the whole application), and reinstalled - it seems to work (but I have not installed the latest update of HSM PRO).
I am checking the network in more detail however, as I have seen some packet errors on the workstation Ethernet port (10G addin card). It is possible when I changed my dual Quadro cards with the newer single one, it may have changed the air flow and cause overheating. If I notice the errors increase, I will add a fan over it to see if it helps
Back to square one - there is a problem with the update file I think
Everything was working after the reinstall
I decided once again to install the latest HSM Pro Experimental Build - and now again keeps asking for the license server, and not finding it.
Anyone else have any trouble installing the latest update?
I don't want to try it again - as it has resulted in inability to find the license server on 2 separate occations
I tried installing the 2016 Dec 6 Experimental build, and I am getting the same results as what was happening with the build 2 versions ago (I have not tried it since then).
I install the PRO license (which is what I have), the installation goes through without a hitch.
When I run, it asks me for my license server - I use 27005@MYSERVERNAME - which is the port used - also verified by LMTOOLS. It then just goes into an endless loop asking for the license server.
A few days ago, I installed Update 1 of Inventor, and it too asked for my license server - but when I entered it as above - it accepted it and proceeded to work.
(Note in my current setup, I tested the install in a VM - having created a checkpoint - when it did not work, I just reverted back to the original setup - so no harm done, but cannot get the new versions to work)
What license manager version do you have?
Laurens Wijnschenk
3DTechDraw
René for Legend.
I got this non reply when I tried to issue a customer support ticket. So it looks like this is my only avenue, and so far the software does not want to recognize my server's license.
Dear Robert Salasidis,
Thank you for contacting Autodesk. My name is Nathan I have received your case for review. With regards to you being unable to install the HSM pro please visit the following link to download the software
http://cam.autodesk.com/inventor-hsm-experimental/
If you are still having issues getting the software to install please post the issues you are having in the HSM beta forums or reach out to the beta support team as we unfortunatly do not support beta software.
http://forums.autodesk.com/t5/hsm-beta-testing-english-deutsch/bd-p/219
I will set this case to a closed status as this information should help resolve the issue. If for any reason you need further assistance please do not hesitate to contact me, thank you.
If you have additional questions about this issue you may reopen the Service Request at any time by replying to this email and I will be very happy to help you. If you experience a new issue, please log a new Service Request to ensure your questions are routed to the appropriate team.
Sincerely,
Nathan Rivera
Global Customer Support & Operations
So 2016 works correctly, 2017 doesn't?
Did you install 2017 on a VM? Have you tried 2016 on the same VM? Does that work?
Laurens Wijnschenk
3DTechDraw
René for Legend.
2017 works as well - even installed 2017 Update 1 of inventor - that worked OK too - picked up the license no problem.
The only thing that does not work is installing HSM Pro Experimental (whichever one from the last 3), and then trying to run it - It asks for a license server, and no matter what - it does not accept it - no error message - just keeps asking for the name of the license server
I have the same problem, support had no solution at this time.
See below, this was the email that I sent out to my local dealer.
It will behave the same way windows7 and 10.
The only good news is they released the new full version of Build 4.2.0.042 / December 14, 2016 which works, but I expect that the new beta updates will cause the same problems except they will make some changes.
The problems started on 12/16/2016I spend 12h yesterday and came up with some results.After double checking everything with you (Local Support), I uninstalled the complete software package, after installing Inventor HSM 2017 4.2.0.042 and applying Inventor R3 update it worked like it supposed to.after Installing Beta Inventor HSM 2017 4.1.0.106 / November 4, 2016 which used to work in the past.It did not work anymore.Then I installed Inventor HSM 2017 4.2.0.042 / December 6, 2016 on top of it.Still not working.Then I found a trick to reset the software (Inventor reset utility is my new friend) verses uninstalling it and installing it again which takes a long time.It worked, it put the software back to Inventor HSM 2017 4.1.0.075 / September 26, 2016which was my original install.Then I tried to install Beta Inventor HSM 2017 4.2.0.042 / December 6, 2016 over it.And id did Not working anymore again.I used the inventor reset utility again to set the software to its original state 4.1.0.075 which is now working.Please open a case and let them figure out what's going on.The PC is running Windows 10 64 bit.Let me know if you have any more questions.I tested a lot more thing port scanning and other possibility's.So the LMN license Tool works.I need o be able to work with the beta versions to get all the benefit of the software.Thank you.Mike
Here is the solution as per BJC from Autodesk support
Basically just add the environment variable ADSKFLEX_LICENSE_FILE with a value port@IPAddrofLicenseServer
How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable
To use an environment variable to specify one or more license servers for your Autodesk products:
@server1;@server2;@server3 (where server is the hostname or IP address of your license server)
If you wish you specify a custom port for the server format the value as port@server where port is the custom port number your license server is running on.
Consider the following when using the ADSKFLEX_LICENSE_FILE environment variable to specify license servers:
Great, thank you.
Have you tried it out?
I guess will know when the next Development version gets released and Installed.
Mike
