HSM Beta Testing (English / Deutsch)
Complex 3D Chamfer Using Flow
6 REPLIES 6
1436 Views, 6 Replies
It seams to be a bit hard to accomplish 3D Chamfers in HSMWorks right now although there seams to be quite a bit of discussion on the topic.
This is the best I could do....
If it was possible to chose 0 stepeovers in flow I could cut the chamfer in one pass which would be ideal.
Is there currently another way?
6 REPLIES 6
Laurens-3DTechDraw
Have you tried Trace?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Doesn't work for steep angles....
jeff.walters
Have you tried 3D Project?
Jeff Walters
Senior Support Engineer, CAM
I didn't have any luck with the transition up the wall.
I will gladly send the file to you if you have any ideas.
jeff.walters
The file would help greatly
Jeff Walters
lenny_1962
are the tops of the spokes on a flat plane?
if so use  a 2d contour with a chamfer mill going too the up turned end and then just do a 3D flow on the small sections of what is left with a 5 passes with a small ball cutter, then circular pattern.
Technology Administrators
