Project member with Viewer role can't visualize PDF file
PLM-miguel.correia
PLM-miguel.correia
Hello everyone,
I am facing a problem of visualization with PDF files for the Viewer role project members.
It is very annoying as we need to share drawings and documents with external persons and we do not want to give them the Editor role.
I have already tried to download and upload the files several times but without success.
If I am not mistaking, the Viewer role project members do not have the permission to download files.
However, I have noticed that word files (doc, docx) have no problem of visualization for Viewer role project as they generate an automatic download of a PDF from the word file.
As we share some documents but also some drawings in PDF can I ask you which kind of extension files you recommend for Viewer role project members?
I have already asked this question on a post that has been already solved in the forum regarding a problem of visualization on Fusion Team (https://forums.autodesk.com/t5/fusion-team-forum/can-t-visualize-file/m-p/7020362/highlight/false), but as it has already been set to solved perhaps it is better to create a new one.
Thank you for your help.
Best regards,
Miguel
Bud_Schroeder_ADESK
Hello Miguel,
Thanks for taking time out to share your feedback with us.  This is a known limitation for PDF files and something that the team is  working on resolving. There is no ETA at this time, but I will pass your feedback on to the team.  The Viewer for PDF files allows download when set as a viewer role and so it was disabled.   One possible temporary workaround would be to use the actual CAD files, or use DWF, or DWFx files.
Thanks again for posting your feedback to the team and hope this helps explain why this  is not allowed and that we are working on resolving this in the future.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
PLM-miguel.correia
Hello Bud,
thank you for your answer.
Is there a way to list which users have a viewer role in projects?
The only way I found is to enter in every project to check manually.
Thank you and best regards,
Miguel
Bud_Schroeder_ADESK
Hi Miguel,
The only way to see the Viewer role is to go to each project. You can see Project Contributors in the Admin panel, but it does not display the sub role of viewer.
This is a great suggestion, can you post it to our Idea board. That is where we capture ideas on new features as well as enhancements on existing features. Once posted, others can add comments and vote on it. That will give us an idea of what people would like to see in future versions of A360.
A360 Idea board:
Thanks again for your feedback and looking forward to seeing this in the Idea board.
Bud Schroeder
Autodesk Inc.
tobias
Hi Bud,
Any news on the viewer role for pdf ?
Tobias
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Following as I'm dealing with it as well.
