Unrecoverable exit code from extractor: -1073741831
I cannot view my Fusion 360 file on web browser...
When I open my design, it fails to display my design and I get the error code:
I saw this post, and I think I am seeing the same issue.
https://forums.autodesk.com/t5/a360-forum/a360-file-viewer-error/td-p/6722952
However, I did not know how I can change the publishing settings, as was discussed in the post.
I can view my file from my local Fusion 360 software, so the file itself should not be corrupted.
Bud_Schroeder_ADESK
Hi Tomoyuki,
Thanks for posting your question to the forum. I went ahead and moved this over to our Fusion Team forum as you mention this is a Fusion 360 file.  Are you able to view and edit the file inside of Fusion 360?  And what happens if you make a small modification to the file and then save it and upload it to A360 again, does that version view?
Thanks in advance for trying this and letting us know how it goes.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Thank you very much for your help.
Yes, I can view and edit my file without problem using my Fusion 360 software.
I only see this problem when I upload it on web browser, and the viewer just does not work.
(I attached the screen shot)
I edited the file and re-saved it, but I still see the same problem.
I also made a duplicate copy of the same file, but this new file experiences the same issue.
Bud_Schroeder_ADESK
Hi Tomoyuki,
Thanks for trying. Can you create a public link with download enabled for this file and share it with me.   If you do not want to post the link here in the forum, you can use the Private Message feature to share it with me.
Thanks in advance for doing this and for trying our suggestions.
Bud Schroeder
Autodesk Inc.
I also have a file in a shared project and suddenly no-one else can open it. All the other files in the project are fine. I also can't access it in the web browser even with a public link. all I get is
Can you please help?
Problem is common across my Mac and PC (I can open it fine on the local software on both, but it's not available to anyone else). Mac version is 2.0.5357 / Mac OS Mojave 10.14.2
Oli
