Fusion Public Share link - URL changing for each version
william
Message 1 of 28
william
The public share link has always been a perpetual link that doesn't change. This is important because it is distributed via email and our ERP system, so any employee or customer can open the link and see the most up to date version of the file.
Something has changed recently, and the link is now changing for each new version.
This is a big problem, we have 10,000 drawings and models (pdf's, and stp files) that we have copied the public share link and uploaded to our manufacturing system, assembly instructions/SOP's, and suppliers, etc.
We have relied on the perpetual link so any changes to the design, we only have to update the file in Fusion Teams, and everywhere the shared link is used - the user sees the updated version.
@ryan.bales @Rafal.Chlod - Why is Fusion now doing this?
We need to get this back to a perpetual link as soon as possible.
Replies (27)
Message 2 of 28
RajkumarIlanchelian
@william We are aware and our apologies. We are actively working to identify what happened here.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 28
william
Thanks for the quick reply.
It has only started happening recently (have only noticed it in the last 2-3 weeks), I initially thought it was someone at our end not following the process correctly.
Already it has cost us thousands in rework, because contractors thought they were looking at the most up to date version of the plans and didn't realize they were in fact looking at an out-of-date version.
I don't know why the developers would muck around with this and break it, when it's been working fine up to now.
How does this even happen? How does someone get to make a change like this, and code released without it being picked up?
Message 4 of 28
RajkumarIlanchelian
@william Valid questions that you have there. Our first order of business is to get customers like you unblocked. As I learn more on what happened I may be able to share details.
Autodesk Fusion
Join Fusion Insider
Message 5 of 28
william
@RajkumarIlanchelian - When can we expect a fix for this?
This is causing so many issues for us every day.
Message 6 of 28
RajkumarIlanchelian
@william @We are expecting either a Thursday or Friday deployment if all the testing goes well. Will certainly keep you posted.
Autodesk Fusion
Join Fusion Insider
Message 7 of 28
RajkumarIlanchelian
@william The problem should be addressed now. We do sincerely apologize for the experience here.
Autodesk Fusion
Join Fusion Insider
Message 8 of 28
william
@RajkumarIlanchelian  Thanks for fixing this.
I updated a couple of files and checked the links; everything appears to be working correctly now.
Couple of questions:
Can you confirm when the change was made that broke the perpetual link functionality? So, I can work out what files are affected here.
Why was the change made? Was it intentional, and if so - why?
Message 9 of 28
RajkumarIlanchelian
@william The issue was introduced on June 10.
Autodesk Fusion
Join Fusion Insider
Message 10 of 28
william
@RajkumarIlanchelian - This issue has started happening again.
Each time I republish a file the public share URL is changing.
What on earth is going on with this? This should not be happening!
Can you please get this fixed asap.
Message 11 of 28
RajkumarIlanchelian
@william Will validate and escalate. Thank you.
Autodesk Fusion
Join Fusion Insider
Message 12 of 28
william
@RajkumarIlanchelian Any update on this?
Message 13 of 28
RajkumarIlanchelian
@william Not yet. I have escalated it to the engineering team to take a look.
Autodesk Fusion
Join Fusion Insider
Message 14 of 28
william
@RajkumarIlanchelian- It looks like someone has corrected this issue now. Public share links are now staying the same when we publish new versions.
Can you please confirm when this issue was introduced so I can figure out what files are affected.
Do you know why this was broken again? Can we get a message to the developers, to stop playing around with this section of code please.
Message 15 of 28
RajkumarIlanchelian
@william I have requêtes for this information.
Autodesk Fusion
Join Fusion Insider
Message 16 of 28
aparna_naik
Hello @william Willam,
We have checked with the team, and they have informed us the last fix was done on June 20. In order to understand the problem you faced, can you please let us know when was the last version of URL updated before you started seeing different public share link being created? We suspect if the last URL was created during the fix period (June 20), this might have created new URL for recent update. Did you observe how this issue was fixed? We appreciate your patience.
Aparna Naik
Autodesk Fusion
Message 17 of 28
william
@aparna_naik - This is unusual then.
I only noticed the issue yesterday when a colleague picked up on it. I was able to recreate the issue myself. Every time I would publish a new version it would change the link.
But that stopped happening approximately 2 hours after I posted on this forum. Idk what is going on then.
It's a bit disconcerting if you rely on this functionality to be consistent and reliable.
Message 18 of 28
william
@aparna_naik  @RajkumarIlanchelian
It has started happening again this morning.
I took a screen video showing the issue. Every time I publish a file now it is changing the link.
Please troubleshoot this ASAP.
Message 19 of 28
william
I created a new file just now and updated 2 times afterwards. Each time the link changes.
This rules out the possibility that bad links are being generated for files affected by June 20 issue.
Message 20 of 28
aparna_naik
Thank you William for sharing the video and sorry to hear that you are facing the issue. I will escalate the issue to our team. Can you please share which version of Fusion are you on?
