file in fase di caricamento - file loading
estseitre
estseitre
Community Visitor
Community Visitor
come faccio a cancellare file che non si vedono nella lista?   Si vede solo il nome e una ruota che indica un caricamento che non avviene mai anche a distanza di ore
Grazie
[Translated]
how do i delete files that are not visible in the list? you only see the name and a wheel that indicates an upload that never happens even after hours
CGBenner
@praise.tomWX9P2
Do you have any ideas on this question, or do you know who might be able to help?
Chris Benner
praise.tomWX9P2
Hi @estseitre
Sometimes the file that shows is from the cache folder. Can you please uncheck the view offline cache as shown
If the file shows still uploading this might occurs since the file stuck in the upload Queue.  Could you please try solution in the following article
File stuck in upload queue in Fusion
Regards
Praise Tom
CGBenner
@estseitre
Hello!  Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
estseitre
Community Visitor
Community Visitor
Non accetto perche non mi avete aiutato a risolvere il mio grande problema....Assistenza PESSIMA
I don't accept because you didn't help me solve my big problem....TERRIBLE assistance
CGBenner
@praise.tomWX9P2
Is there any other suggestion you might have for @estseitre ?
Chris Benner
praise.tomWX9P2
Hi @estseitre
Sorry to hear that the suggestions didn't help.
In general the files stuck in upload Queue is resolve by the following article File stuck in upload queue in Fusion
If the solution didn't help please rename the Autodesk Fusion 360 folder with the following directory
Windows: C:\Users\ <
username> \AppData\Local\Autodesk
Mac:  users/ <username> /Library/Application Support/Autodesk
Praise Tom
