Hello. I am having this problem. I am a school team member. I'm uploading the files to the team. I designed each piece separately. Now I want to do assembly but when I drag the files I get an error. I think it gives this error because these files are not installed on my computer. Could you help please ?
ERROR: Design not saved yet .
Cannot insert external components into this design because it has never been saved.
Save the design, then try to insert again.
Solved by RajkumarIlanchelian. Go to Solution.
@151820183084 @This error is pointing to the current design that you are trying to drag it into. Open a new design - save it first and then drag in the other design and this should work.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
This tricked me also, and I found this answer with search. You should update the wording to be non-ambigious.
"Cannot insert external components into this design because it has never been saved.
Save the design, then try to insert again"
Perhaps change it to:
You must save your current workspace before you can insert a component.
