Fusion Team, Data, & Project Management
Need help managing your Fusion (formerly Fusion 360) Team Hub? Have questions about adding or removing team members, or permissions? Get help from the collaboration experts.
Design not saving yet
2 REPLIES 2
1096 Views, 2 Replies
Hello. I am having this problem. I am a school team member. I'm uploading the files to the team. I designed each piece separately. Now I want to do assembly but when I drag the files I get an error. I think it gives this error because these files are not installed on my computer. Could you help please ?
ERROR: Design not saved yet .
Cannot insert external components into this design because it has never been saved.
Save the design, then try to insert again.
2 REPLIES 2
@151820183084 @This error is pointing to the current design that you are trying to drag it into. Open a new design - save it first and then drag in the other design and this should work.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
rsilvers129
in reply to: 151820183084
This tricked me also, and I found this answer with search. You should update the wording to be non-ambigious.
"Cannot insert external components into this design because it has never been saved.
Save the design, then try to insert again"
Perhaps change it to:
You must save your current workspace before you can insert a component.
