Fusion Team, Data, & Project Management
Need help managing your Fusion (formerly Fusion 360) Team Hub? Have questions about adding or removing team members, or permissions? Get help from the collaboration experts.
Autodesk account language
5 REPLIES 5
gabor.kugler
333 Views, 5 Replies
My autodesk account language changed to german, without asking me. How do I change it back to english?
Tags (2)
Labels (2)
5 REPLIES 5
Rafal.Chlod
in reply to: gabor.kugler
Hi @gabor.kugler, thanks for posting.
The account language should be related to the language used by your web browser. Check settings and try to switch language to your desired one.lang.png
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
gabor.kugler
My browser is language is swedish, and I'm pretty sure that the account language was english earlier.
Rafal.Chlod
I think it's still worth trying different language configurations.
Alternatively, try logging into your account in another browser and see if it happens there too.
Rafał Chłód
Thank you!
Simple solution.
Autodesk support kept sharing some useless FAQ items about changing desktop version language while the problem was the browser language. The conversation lasted to the point that support people stopped responding. The problem indeed goes away if you ignore your customer in need.
Rafal.Chlod
Hello @sebastjan_brezovec6QQB8, thank you for sharing your opinion.
I believe the suggestions that you received were helpful in some similar issues in the past, that is why you got them in the first place. Sorry to hear that they were not working on your case. I assume that one solution may work for a specific user while someone else with a different configuration but the same issue will need another approach. I am glad that my suggestion helped you as well.
Not sure what happened with the communication in your internal case. It may happen that some filters are blocking messages on both sides but we are trying also different ways to contact users if possible. Sorry to hear about the inconvenience. You can also try to start a chat in such cases.
Rafał Chłód
Technology Administrators
