Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Why can't I move this circle?
6 REPLIES 6
karl
1244 Views, 6 Replies
I've been away from Fusion for three or four months and apparently I've forgotten, well, almost everything.  I've started a new project and sketch, and the only thing I've created so far is a circle at the origin.  I'd like to move this circle 4.031" to the right (in the direction of increasing X).  I select the circle, right click, select Move/Copy, enter 4.031 in the X box, click OK, and nothing happens.  Same thing if I try dragging the right arrow.  If I create a circle that's not on the origin, I can move it fine, but I don't have its coordinates, so I don't know exactly where it is.  I realize I could find them (though that's another issue), but I'd like to understand why the original circle remains locked at the origin.  File and screencast below.  Thanks for any tips.
Tags (1)
Labels (1)
  • 2D
6 REPLIES 6
TheCADWhisperer
in reply to: karl
You have a Coincident Constraint between the Origin and the center point of the circle.
Delete the constraint and you can move the circle.
TheCADWhisperer
in reply to: karl
@karl wrote:
.... but I don't have its coordinates, so I don't know exactly where it  is.
YOU define the coordinates (position).
Two dimensions from the Origin (x,y) and you know EXACTLY where the center of the circle is.
Any time you are tempted to use Move, you should stop and ask questions.  There is usually a better technique than Move.  This is perhaps the most miss used tool in Fusion by beginners.
karl
in reply to: TheCADWhisperer
Aah, got it. Thanks!
karl
How do I determine the coordinates of something once it's been created?
TheCADWhisperer
in reply to: karl
YOU control the coordinates by dimensioning
Put in the two dimensions - they will read the current distances.
Change the dimensions if desired.
This is what Driving Dimensions (Parametrics) is all about.
karl
Thanks again.
