I'm running ios16.2 (the latest) and the latest version of the fusion360 app (v2.6.0.1) and I'm experiencing the classic "everything is white" view unless I use my finger to rotate/move the object at which point it becomes visible and stays so until I remove my finger at which point the screen goes white. (with the white screen, I can still see the toolbar/menu things, just not the object)
It appears just like this prior problem: https://forums.autodesk.com/t5/fusion-360-support/problem-with-fusion360-ios-app/td-p/11369747 but I'm running with a newer OS than what appeared to fix the problem previously (16.0.2). Any ideas or suggestions? Thanks!
Solved by cobrageek. Go to Solution.
Well, now I feel silly. But on a whim I thought to try completely exciting the app and restarting it. Now it works just fine. Sorry to pester everyone. But maybe someone else will benefit from reading this :-). Thanks for the cool app!
It sounds like you're experiencing a rendering issue with Fusion360 on iOS 16.2. Here are a few things you might try to fix it:
If none of these steps work, it could be a bug with the app version you're using. In that case, I'd recommend contacting Fusion360 support and letting them know about the issue. They might have a patch or a workaround for you.
