Fusion Support
What is 'Objects to cut' ??
2 REPLIES 2
drgert1
106 Views, 2 Replies
Hello All,
F360 noob here.
I imported the STL from the web. It's a cap for Canon camera. I need to design a hole and extension into it. But I get stuck with tool asking 'Objects to cut'.
I opened the design, mad a sketch on what seems to be the inside surface of the cap, made a circle, and now I want to extrude / cut the hole through the part. But it is not working.
I am so sorry my knowledge is so limited, but I have no  idea what the tool is trying to tell me here. Thus I am unable to respond properly. I tried clicking on the solid body indicating that this is the body I want to cut, but nothing happens. I must be missing something very fundamental in the use of F360. How do I get this design step resolved? Could you please explain the underlying principle here? What property of the design 'body' did I miss during import so that I fail to cut the hole?
I get a popup :
Click on more info does not do anything.
I've attached the STL from the web. That's all I have.  Now the forum is telling it can't attach the file.
What is missing now?
Gert
Tags (1)
2 REPLIES 2
davebYYPCU
in reply to: drgert1
STL files may have to be zipped but we don't need it,
Fusion files are ok to attach, with the mesh body in it.
You can't model directly on a Mesh Body with normal tools.
That body should be converted to a solid body, or you could consider MeshMixer as more suitable software for working this way with mesh bodies.
Might help...
drgert1
Adding the STL zip file, FYI.
Best,
Gert
