Has McMaster-Carr been removed Fusion 360?
The knowledgebase still references it:
Solved by Bjanders. Go to Solution.
Nope, the McMaster-Carr Component option is still under the Insert drop-down.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
McMaster-Carr is still available under the Insert menu using a Fusion 360 Personal License also.
John Hackney
Retired
Thought so,
only thing I can suggest, is there is a tool active, that prevents the Insert until the tool is completed.
Might help....
It didn't show because I was in offline mode. I was in offline mode because of the Server Verification Warning:
That I just added some info to in this topic:
Surprisingly though, the two other "insert part" options were available in offline mode, but not McMaster-Carr.
