Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Was McMaster-Carr removed?
5 REPLIES 5
Bjanders
602 Views, 5 Replies
Has McMaster-Carr been removed Fusion 360?
The knowledgebase still references it:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
5 REPLIES 5
jhackney1972
in reply to: Bjanders
Nope, the McMaster-Carr Component option is still under the Insert drop-down.
John Hackney, Retired
davebYYPCU
in reply to: jhackney1972
In Personal Licence? I don't have both to check.
jhackney1972
in reply to: davebYYPCU
McMaster-Carr is still available under the Insert menu using a Fusion 360 Personal License also.
davebYYPCU
Thought so,
only thing I can suggest, is there is a tool active, that prevents the Insert until the tool is completed.
Might help....
Bjanders
It didn't show because I was in offline mode. I was in offline mode because of the Server Verification Warning:
That I just added some info to in this topic:
https://forums.autodesk.com/t5/fusion-360-support/unable-to-validate-a-security-certificate/td-p/104...
Surprisingly though, the two other "insert part" options were available in offline mode, but not McMaster-Carr.
