Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
UV unwrapping to make this design 3d printable (using TPU).
2 REPLIES 2
asbissonnette
117 Views, 2 Replies
Not sure how to title this as I am assuming fusion probably doesn't have this functionality, or anything like it. In the screenshot, the red arrow is pointing to the component I am referring to. Ideally, I would like to print this "wall" flat on the bed and with a very thin back wall (colored green for reference) so I could flex it into the final position. One reason is because I would like to make the front (white) columns a different color than the back wall, so printing flat would make this a lot quicker to print.
Is there a *quick* *easy* way to "unwrap" this wall for printing purposes (meaning not bringing into blender)? If not, is there a way to at least know the circumference of the wall so I can redesign it flat?
Tags (1)
2 REPLIES 2
Perhaps. Using Sheetmetal and unfold.
Thanks! Good idea!
