Using Body to Split second Body - Error
Corvin.Huber
Corvin.Huber
I am Trying to use this body:
to split this body: 
 And get: Error: Coincident tools would create illegal or non-manufacturable bodies. Try with separate tools.
This Method worked earlier:
 I have used the "Inspect Interference" Tool with "Include Coincident Faces" but there are no coincident faces detected.
What can be the cause for this?
Thank you!
jhackney1972
Created a couple of Surfaces that allowed to do the Split Body correctly without error.  Model attached.
John Hackney, Retired
TrippyLighting
Use the combine-cut tool instead of split body.
The split body tool is not the right tool to "split" 2 solids.
@jhackney1972's workflow uses surfaces for splitting, which is another way of accomplishing what you are looking for.
Corvin.Huber
Thank you!
Works, but very complicated.  Combine/cut is easier!
Corvin.Huber
Excellent answer, as always ... thank you, Peter!
