Lost Fusion 360 Files
lagunacamacho
lagunacamacho
Hello
I'am unable to find my Fusion 360 files. I have already checked the cache files and found nothing.
Do you know how to solve this?
Greetings
jhackney1972
Need a bit more information, are you logged into Fusion using your Autodesk ID and Password.  What does you Data Panel show, a screen capture would be nice.  What do you have selected as your Storage type, your Team or Single User Storage?  I am using a Team (red box).  What do you see if you go to the Web Database (red arrow)?
John Hackney, Retired
lagunacamacho
Hello
Thank you for answering this fast. Firstly, yes, I'am logged with my Autodesk ID. I think I have selected my "Team" as my storage type, also, when I go to my "Web Database", I don't find any of my projects.
Here is a screenshoot of my Fusion 360 panel, it only shows one project, but I had much more.
Thank you very much
lagunacamacho
Hello
Thank you very much
jhackney1972
What you need to do make sure you are logged into Fusion using the same Autodesk ID you used to create your projects and then follow the video.  If you are logged in correctly, you will see all your projects.  If you do not see them, I would suggest you have a different Autodesk ID and they were created under it.
lagunacamacho
Hello
Thank you for your help, It actually worked
Greetings
