Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
User Parameter Function doesn't validate
3 REPLIES 3
petrara
498 Views, 3 Replies
petrara
Fusion 360 version 2.0.5350 - my uni did not upgrade yet to latest version.
Not sure if this is a bug or I'm not using the formulas correctly.
Trying to do some operations with a defined User Parameter, but some operations fail.
Parameter: DrvWheel_DIA = 80mm (see attachment)
 Can Do:
  • DrvWheel_DIA + <number>
  • DrvWheel_DIA - <number>
  • DrvWheel_DIA * <number>
  • DrvWheel_DIA / <umber>
Can NOT Do:
  • DrvWheel_DIA ^ <number>
  • sqrt(DrvWheel_DIA)
  • pow(DrvWheel_DIA, <number>)
Obs: sqrt(), ^ and pow() work fine when only numbers are introduced, with no variables.
Please advise.
 Can Do:
Can NOT Do:
Please advise.
3 REPLIES 3
jhackney1972
in reply to: petrara
jhackney1972
You cannot take a square root of a parameter value that contains units.  The answer can be found here.  All you have to do is remove the units from the variable, inside the parentheses, by dividing by 1/(units).
John Hackney, Retired
petrara
in reply to: jhackney1972
petrara
Thanks for the tip.
It's really confusing and I'd expect more from Autodesk and Fusion... If it can't identify the value and the unit is quite...dumb from software point of view.
Thanks for the tip.
I think it is quite smart that Fusion 360 is unit-aware. A patch of 1x1 cm is 1 cm^2, but it is 100 mm^2, so the number depends on the unit.
My two cents: it would be nice to get a user warning explaining that the formula is red because of unit related issues.
