I'm having a hard time trying to push an Eagle 4 layer 0.8mm PCB to Fusion 360 for M-CAD designer. As per Eagle DRC Layer stack PCB thickness is 0.82mm. After pushing to Fusion 360, the PCB thickness is showing as 0.75mm in Fusion 360!! I've tried searching these forums, and instructions if any are completely outdated. E.g. https://knowledge.autodesk.com/support/eagle/troubleshooting/caas/sfdcarticles/sfdcarticles/The-thic...
There is no resemblance of the Fusion 360 to current day whatsoever and I'm not able to follow the instructions as I'm basically a Eagle user.
As you can see, this is a known problem from past 2 years which you seem to have failed to fix!! I feel as if we are paying Autodesk for beta testing their software!
As we are into critical deadlines, please help me urgently.
