Fusion Support
Update sketch after using combine/cut
2 REPLIES 2
jknoetze
93 Views, 2 Replies
I am creating a box and after using combine/cut function the original sketch of the target body does not show the changes.
I need to modify the cutout made in the target body after combining due to material thickness variations.
2 REPLIES 2
jhackney1972
in reply to: jknoetze
Please attach an example of your need and explain what you desire fully.  To attach your model, open in Fusion, select the File menu, then Export and save to your hard drive.  Attach this file to a reply post.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jknoetze
in reply to: jhackney1972
Dear jhackney, I have devised a work around. I am knuckling down to construct my project. When completed I will share my problem with you.
