Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Update Failure, log attached
3 REPLIES 3
callum311
499 Views, 3 Replies
Computer has solid internet connection, have tried restarting both the app and the computer. Currently running Fusion 360 is v2.0.6045. I'm on a mac running MacOS Mojave 10.14.3 if that makes a difference.
Tags (3)
3 REPLIES 3
MoshiurRashid
in reply to: callum311
Thank you for posting. I think you should clean uninstall fusion and then reinstall it with updated version.
This article said so.
 https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
The version 2.0.6045 is what we released in July,2019. With updated SSl certificates there is no way for us to live update from builds that are older than 6 months. Uninstalling Fusion and re-installing is the only way to get to the latest 2.0.7805 version.
I am really curious on why you were not able to live update the last 7 months. Do you work only in offline mode? If you do work in online mode were you never notified that a new build is available?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Ah that makes sense. I just haven't used the software in that long apparently!🤣
Technology Administrators
