As per the View Job Status instructions I am posting here and including the diagnostic log.
I have rebooted a few times, no help.
Solved by RajkumarIlanchelian. Go to Solution.
@lee9966 I see this error in the log files (thank you for attaching the logs) - SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC
Search for the error on the forums and there are various people that solved this either by changing wifi to a ethernet connection and in some cases a mere restart of the machine seemed to have solved the issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Glad to know that it worked. We will see if there is an opportunity for better messaging from us on such failures.
Autodesk Fusion
Join Fusion Insider
