Fusion Support
Update corrupted 23 versions of the last 2 weeks of work.
19 REPLIES 19
Message 1 of 20
Upekrithen
928 Views, 19 Replies
I have been working on a file for the last two weeks, 23 versions. In the middle of that, fusion needed to be updated. No problem. I saved, then updated, which asked me to restart fusion. I did so, and now NONE OF THE VERSIONS I have been working on will open, and all are said to be corrupt. Even when I go online and download the file from, say, 10 days ago, it STILL also says it is corrupt. But other files that I haven't been working on, do work. Please help.
19 REPLIES 19
Message 2 of 20
@Upekrithen Would it be possible to invite raj.kumar.ilanchelian@autodesk.com into your project? I can take a quick look.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 20
shinderu
in reply to: Upekrithen
Hi @Upekrithen, Thanks for reaching out.
Could you please share the impacted datasets/files? I can try to recover the datasets for you.
Can you also share the diagnostic logs generated right after the open of the file is tried? This will help in investigating the root cause of the issue.
Here's the documentation link - How to collect the Diagnostic Log Files for Fusion
Rutuja Shinde
rutuja.shinde@autodesk.com
Senior QA Engineer
Autodesk, Inc.
Message 4 of 20
I have invited @RajkumarIlanchelian into the project.  How do we communicate?
Message 5 of 20
@Upekrithen Thank you. For now, let's use this same forum thread. I am taking a look now.
Autodesk Fusion
Join Fusion Insider
Message 6 of 20
@shinderu I have also passed on the file to you for triage.
Autodesk Fusion
Join Fusion Insider
Message 7 of 20
So...  any thoughts?
Message 8 of 20
@Upekrithen Sorry, give us one more day.
@shinderu is following up with the team with the data you provided. We believe we can fix this data internally and save it as a new version for you but we will certainly get back.
Autodesk Fusion
Join Fusion Insider
Message 9 of 20
Thank you!  I'll check back.  I appreciate your help, immensely.  😄
Message 10 of 20
shinderu
Thank you for your patience during this process. In order to further our investigation, would it be possible to bring rhudaynath.diwate@autodesk.com and rutuja.shinde@autodesk.com into the hub?
Rutuja Shinde
Senior QA Engineer
Autodesk, Inc.
Message 11 of 20
Upekrithen
Yes.  I made a separate project called "corrupt file" with the only file in it being the corrupted file.  Is this a file problem or a "reinstall the software" problem?
Message 12 of 20
Upekrithen
Oh, and I added all three to it.
Message 13 of 20
shinderu
Thanks @Upekrithen. We suspect the latest versions of the file got corrupted after the update. We are interested in checking the older versions of the design. Is it possible to invite us in the original hub where we have older versions of the design.
Rutuja Shinde
Senior QA Engineer
Autodesk, In
Message 14 of 20
Upekrithen
I have simply remade it at this point.  I'll just make triplicate copies with different file names before I ever update again.  Sorry, I'm super iffy about sharing any files, so thanks for the efforts.
Message 15 of 20
shinderu
Apologies for the inconvenience and additional efforts you've had to make.Unfortunately, without the older versions, we're currently unable to recover the shared version.
I want to assure you that me and the team have noted the issue and are initiating an investigation into why the update may have caused this problem. Our aim is to prevent such occurrences in the future. Your understanding is greatly appreciated.
Rutuja Shinde
Senior QA Engineer
Autodesk, In
Message 16 of 20
shinderu
in reply to: shinderu
Hi @Upekrithen, after few more trials and effort we were finally able to recover the dataset. I am attaching the recovered file here. See if the files comes to use.
Rutuja Shinde
Senior QA Engineer
Autodesk, In
@shinderu - per request of OP the file has been removed.
Message 17 of 20
Upekrithen
Yes, but can you please remove the files from public access here?  This is why I didn't want to share any of them to begin with, but tentatively did anyway bc you're autodesk.
Please delete the file.  I have what I needed.  Thank you.
Message 18 of 20
shinderu
Sure, the file has been removed.
Rutuja Shinde
Senior QA Engineer
Autodesk, In
Message 19 of 20
Upekrithen
Thank you!  And thank you for working on it.  Did you ever figure out why the update corrupted it?  And how I can avoid all this in the future?  At the moment I am simply saving every time I do anything significant, as a different file name.
Message 20 of 20
shinderu
At this moment, the root cause of this problem remains unclear. I understand your concerns and want to assure you that encountering such compatibility problems with our new updates is not a typical occurrence. However, please be assured that the team and I are diligently working to understand and avoid any such occurrence in future.
I appreciate your understanding and thanks again for bringing this matter to attention.
Rutuja Shinde
Senior QA Engineer
Autodesk, In
