Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Unexpected behavior with selecting extrusion profiles
2 REPLIES 2
Alpdoganer
180 Views, 2 Replies
When I try to extrude some profiles on a particular model, the selection randomly changes when I finish the operation. Sometimes editing the feature causes stuff to get mixed up as well. Because of this bug I can't finish my design, whenever I try to select profiles they always either end up getting deselected randomly or other profiles get selected which were not selected before.
I don't know if it's an issue caused by me, an issue with my installation of Fusion, or a bug that can be reproduced.
Tags (1)
2 REPLIES 2
g-andresen
in reply to: Alpdoganer
Hi
In my experience, this is caused when you use complex sketches and have (too many) overlapping profiles.
günther
jhackney1972
You do have a jumbled sketch here.  I believe you will have better success if you reverse your method of getting a final plate.  I have no idea the final holes or other features you need but i believe it will be easier to select the areas you do want cut out from a solid plate.  The video will illustrate.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
