Fusion Support
Report issues, bugs, and or unexpected behaviors youā€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Unable to setup Fusion 360 for your autodesk account!!
2 REPLIES 2
1129 Views, 2 Replies
it was functioning normally at first , later there  were login fail. now I am getting the message that unable to setup fusion 360. please help me. its my student version.
2 REPLIES 2
innovatenate
Hi there! Sorry to hear about the difficulties with Fusion 360. This is most likely related to a network connection issue. There are some suggestions in the below link to help determine if it
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Una...
Fusion 360 requires access to the list of domains and ports in the below link.
https://knowledge.autodesk.com/support/a360/troubleshooting/caas/sfdcarticles/sfdcarticles/Network-C...
Do you know if the network is configured to have access to these?
There is a list of suggestion in the below links that may be helpful.
Please let me know if you have any questions. If you can manually gather the log files (see below link), they may contain some further information we can use to troubleshoot the issue.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Nathan Chandler
Principal Specialist
in reply to: innovatenate
i did modify the firewall & and proxy settings, now it is working.
1. 80 and 443 ports are opened.
2.added the proxies (copy paste)
thank you so much.
