- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am making a microSD card holder for myself in Fusion 360.
I downloaded an STL model of a microSD card, imported it into F360 as a mesh object, scaled it appropriately, and converted it to a solid. Then, I projected the solid onto a new sketch plane, without the "linking" option.
There were a couple missing lines around the projected sketch, but I added lines to close it off. When I double click on any line in the sketch, the entire outline is selected, so it does infact appear to be a closed sketch. Example:
I've read in other forum posts that the shape needs to be fully constrained - but how can I do that with such a complex shape? When I select the entire outline, it is a total of 148 objects - primarily because the round corners are not actually arcs - they are a bunch of small straight lines.
This is the model I downloaded and imported as a mesh:
https://grabcad.com/library/micro-sd-card
I've attached my F360 file in case anyone would like to take a look at it. But, all I'm really trying to do is project the outline of the microSD card model onto a plane, then extrude the outline of the card via the "cut" mechanism so I can create a microSD card shaped hole in the surface. Hopefully that makes sense.
Thanks!
David
