Fusion Support
UI BUG
3 REPLIES 3
durahl
215 Views, 3 Replies
UI BUG
Greetings!
For the longest time I've noticed some of the Tool Properties Windows not fully opening at times making them a pain to navigate since you can only resize their Width but not their Height thus necessitating the cumbersome navigating via Scrolling...
Today it kinda hit me it being caused on whether the lefthanded Data Panel was occupying parts of the Workspace or not:
Properties Window mostly closedProperties Window mostly closed
Without the :up_arrow:Data Panel visible the Tool Properties Windows would fully open like in the below example with the Rectangular Pattern Properties Window:
Properties Window fully openedProperties Window fully opened
In case this plays any role - Im on Win11 22H2 and my Screen Resolution is 3840x2160 @ 200% Scale ( on this Machine )
Soo yeah...
Cheers 😃
[edited]
3 REPLIES 3
TheCADWhisperer
in reply to: durahl
You can drag the lower right corner to resize - but they didn't make it obvious.
HughesTooling
in reply to: durahl
I reported several times over the last 8 years or so, guess no one cares!  As you've shown If you swap the dialogs the one docked to the edge of the screen will resize correctly. In the past this used to be remembered across sessions but they broke that while "improving " the UI a few years ago.😞
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
in reply to: durahl
Looking again I see you didn't swap the windows. If you do the one docked to the right side will resize like this.
Mark Hughes
