Wouldn't allow for full un-install, now will not allow re-install. Any help would be appreciated. Streamer log attached.
Solved by dooyoul_chung. Go to Solution.
Glad to hear that suggested solution is working for you. 'accept solution' would be helped for similar user cases.
Thanks.
Please pay attention to Message #4. You should select the Accept Solution on the post that solved your question and issue. Take a look at this article to see why and how.
Since you are new to the Forum, I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
