Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Trouble deriving complex models
0 REPLIES 0
Message 1 of 1
evandiplacido
228 Views, 0 Replies
I am making a 6 axis robot arm. I made the upper arm as a prototype first because it's quite complicated.
I made the lower arm next. Now I'm trying to add the upper arm into the lower arm.
Whenever I derive the upper arm, all the joints get very messed up.
When I "Insert into current design", it works well. The only thing I found that didn't transfer over were the motion studies, which I can easily redo. However, I need to modify it a little, which means I need to break the link.
This message box is shown:
With both options, it always results in the following error:
I think the solution would be to break the link of everything in the upper arm, however I have a thousand components in it, and I don't want them disconnected.
How do I derive or add the upper arm into my lower arm without breaking anything and also be able to modify it?
I cannot provide any files of my robot arm, but I can answer questions and share images.
Tags (3)
0 REPLIES 0
Technology Administrators
