Converting a self-intersecting surface into a solid
ahmed3ZMZE
ahmed3ZMZE
Given the following surface, built using a closed path and a sweep profile,
there will be a self-intersecting surface:
A simple patching of the upper side works, but fails on the lower edge since it is self-intersecting. My goal is to build a solid body; what can I do?
For context, this is a contrived example to demonstrate my goal of building a volcano-like tapering of the sides of random sketch shapes. It is worth mentioning that I have tried to use a loft operation with an intermediate offset of the sketch shape, but got some weird behaviour. It would seem like this would be rather straight forward to implement, but I am new to CAD, in general, and F360, in particular.
FWIW, here's the link to the design: https://a360.co/45o947p
TrippyLighting
That cannot be done without creating interior surfaces, which will likely lead to continued modeling problems.
The boundary fill tool can create a solid, but if you use the section view tool in the inspect menu, you'll find that you have interior geometry, which should not be the case.
A loft to a 2nd profile is definitely the right tool.
ahmed3ZMZE
Fair enough @TrippyLighting , but wouldn't then make sense for this loft functionality to work consistently across the profile? Why is there a "crease" in the resulting solid?
Am I missing something or is this a bug?
ahmed3ZMZE
Seems that the "Direction" option for the profile option in the loft dialog helps and even precludes the need for an intermediate (middle) profile in this case. However, with a slightly more elaborate base profile (the one that defines the "volcano mouth" shape), self-intersection happens for some reason. I will follow up on this as soon as I get your feedback. I appreciate it in advance!
P.S. Rhino 7 has a much more predictable loft behaviour and I have as much experience in it as in F360.
