Announcements
Triming a pattern that is extrudded
infoYYJRS
infoYYJRS
I can't trim my pattern using the split body tool, could anyone point me to what i am doing wrong?
Replies (8)
g-andresen
I recommend this way.
günther
infoYYJRS
I see, but that gives me the negative pattern and doesn't solve my question... 😞
g-andresen
What I showed in the screencast is the principle.
In your case you just have to cut out the corresponding profiles.
günther
infoYYJRS
Thanks @g-andresen  but i still don't get it
TheCADWhisperer
These examples that you are attaching do not follow the technique that I demonstrated to you some time ago???
Is the first sketch fully defined? If not, why not?
Are there any unresolved issues highlighted in the Timeline?  If so, why?
g-andresen
then try it like this:
günther
infoYYJRS
I guess i had to remove bodies not delete.
thanks alot @g-andresen  it made sense to me!
g-andresen
Instead of removing, you can also put the cut off parts into a group and hide them.
Timeline and browser remain clearer.
günther
