Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Triming a pattern that is extrudded
8 REPLIES 8
Message 1 of 9
infoYYJRS
283 Views, 8 Replies
I can't trim my pattern using the split body tool, could anyone point me to what i am doing wrong?
8 REPLIES 8
Message 2 of 9
g-andresen
in reply to: infoYYJRS
I recommend this way.
günther
Message 3 of 9
infoYYJRS
in reply to: g-andresen
I see, but that gives me the negative pattern and doesn't solve my question... 😞
Message 4 of 9
g-andresen
What I showed in the screencast is the principle.
In your case you just have to cut out the corresponding profiles.
günther
Message 5 of 9
infoYYJRS
Thanks @g-andresen  but i still don't get it
Message 6 of 9
TheCADWhisperer
These examples that you are attaching do not follow the technique that I demonstrated to you some time ago???
Is the first sketch fully defined? If not, why not?
Are there any unresolved issues highlighted in the Timeline?  If so, why?
Message 7 of 9
g-andresen
then try it like this:
günther
Message 8 of 9
infoYYJRS
I guess i had to remove bodies not delete.
thanks alot @g-andresen  it made sense to me!
Message 9 of 9
g-andresen
Instead of removing, you can also put the cut off parts into a group and hide them.
Timeline and browser remain clearer.
günther
