The "HOLE" drop down has just started to operate when I click the "right" mouse button preventing access to the function tree SO I am prevented from working. How do I disable the Right key being assigned to "HOLE" ?
Solved by ryan.bales. Go to Solution.
I'm not exactly sure what you are meaning, but it sounds like you are talking about the right click gestures. If you hold right click and move to the lower right it opens the hole command.
Does hole come up with any right click?
Yes, the hole tool opens preventing access to any other fontion. Making Fusion useless.
Tha nks for your help.
Jim Rainey
I have same problem. When click right mouse (even mouse in the air) it will trigger hole tool.So I can't access any other dropdown menu.
