Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
The "HOLE" drop down has just started to operate when I click the "right" mouse
3 REPLIES 3
tannerridge747
320 Views, 3 Replies
The "HOLE" drop down has just started to operate when I click the "right" mouse button preventing access to the function tree SO I am prevented from working. How do I disable the Right key being assigned to "HOLE" ?
Tags (1)
3 REPLIES 3
ryan.bales
in reply to: tannerridge747
I'm not exactly sure what you are meaning, but it sounds like you are talking about the right click gestures. If you hold right click and move to the lower right it opens the hole command.
Does hole come up with any right click?
Ryan Bales
Fusion 360 Product Support
tannerridge747
in reply to: ryan.bales
Yes, the hole tool opens preventing access to any other fontion. Making Fusion useless.
Tha nks for your help.
Jim Rainey
chouch0u
I have same problem. When click right mouse (even mouse in the air) it will trigger hole tool.So I can't access any other dropdown menu.
