I'm trying to engrave text into something right now and i make a sketch and i put text in the e sketch but when i go to extrude it nothing happens and i just get an error i've tried making multiple sketches multiple times now and nothing will happen i just can not extrude text at all i've restarted my whole computer twice nothing happens still extruding works and sketches work just not text.
thats the error
also its only broken in the one file that i'm using and only one component and only one of the faces on the component (just so happens to be the one face i want to put text on)
Solved by leo358JY. Go to Solution.
okay here you go the text on the component called "front cover" is the one that need to be extruded
never mind turns out the sf pro text font doesnt work in fusion i dont know why but whatever i quess just dont use that font
