Text Commands wont let me type, its protected
windcrest
windcrest
Community Visitor
Community Visitor
I'm just getting started with Fusion360. I went to create a Sheet Metal project, noticed that I didnt have the 6 starter rules. So I need to do command "SheetMetal.ResetLibraryRules". But when I view the Text Commands area I am unable to type anything into that box, it's a protected field. How do I get the text commands area to be unprotected so I can run a command?
Rick
windcrest
Community Visitor
Community Visitor
Oops, never mind. I see that the text command box is a narrow box at the bottom. I was trying to type into the larger result box above it, duh.
jhackney1972
The Text Command dialog box is not protected.  Are you typing on the lowest line and do you have TXT select for input?
John Hackney, Retired
