Crash on text size change
jacob.michaels
jacob.michaels
Hi forum -
I've had this long-standing issue where when I change my text size in drawings, Fusion will freeze. It won't respond to anything besides task manager. It happens a lot more than I'd like it to, maybe every other drawing I make crashes at some point. I don't have crash reports since I have to end the task manually
Has anyone else had this issue?
Phil.E
Thanks for reporting this. Are you referring to text in 2D drawings, or text in sketches in 3D design?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
liang_chen
Can you pls help to launch Process Explorer when work on Fusion? Please create mini dump files from both AcCoreConsole.exe and Fusion.exe when issue happens, and share the files with us. They will be helpful for us to check which processes have particular handles opened or DLLs loaded. You can also send them via mail. My mail address is 'Liang.chen@autodesk.com'
https://learn.microsoft.com/en-us/sysinternals/downloads/process-explorer
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
jacob.michaels
This is only in 2D drawings
jacob.michaels
I'll do this thanks.
Also, I should note that this issue also applies to changing the scale of a drawing view as well, not just text
