Tangent plane bug
Tangent plane bug
daniel_lyall
Mentor Mentor
Tangent plane bug
daniel_lyall
I found this bug when validating my way to do what was needed in this post https://forums.autodesk.com/t5/design-validate-document/how-to-counterbore-a-hole-on-a-cylinder/td-p...
Screencast and file attached
All it is, try and do a tangent plane and select a origin faces for it to be squire to and see what happens, as a test I did what can be seen in the screencast and it worked as it should.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Phil.E
Daniel,
I don't see a screencast, but are you perhaps seeing this bug?
https://forums.autodesk.com/t5/design-validate-document/tangent-plane-glitch/td-p/6563777?nobounce
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
daniel_lyall
Here's the screencast same bug as that post
Daniel Lyall
The Big Boss
Mach3 User
Phil.E
Daniel,
Thanks, that is exactly what  I was thinking. I've added this case to the bug report.
Best regards,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
