Dimension formula click-to-enter bug
matt
matt
I frequently enter and edit dimension formulae by clicking on existing dimensions.  This no longer works properly.
To reproduce:
* Create a new design and select the model workspace
* Create a sketch
* Create three sketch lines
* Dimension two of them, say 10mm and 20mm
* Hover over the dimensions: Note that they're named 'd1' and 'd2' as expected
* Dimension the third element as the sum of the first two:
  * Start the dimension tool as usual
  * Click on the first element; 'd1' appears in your formula
  * enter +
  * Click on the second element: Note that 'd1' appears again in your formula.
  * Note also that hovering over the second element while still editing the third dimension incorrectly displays 'd1'
It seems that the 'hover' or 'click to enter' feature always repeats whichever dimension name was first selected.
-Matt
FrankCao
Hi matt,
Thanks for reporting the issue. This is not a new issue and we have internally logged a bug to track it for some time. Our developer is still investigating the fix for this problem. Hopefully we will fix it in next several updates.
Frank
