experiencing issues while saveing and working offline and GPU rendering
i am experiencing issue while exiting and saving project
the name can be saved but the location tab is non-editable
after pressing save without editing the location(which is non-editable) this appears
after looking on the forums it showed to work offline but some options can not be found as shown by others
and plus while rendering
MY AMD IGPU is only used as shown by MSI afterburner
MY R7 M440 is sitting ideal at 2%
tried to change the catalyst setting to high perfomance but still this problem occours
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion community!Smiley Embarassed  I'm sorry you are experiencing this issue.
I understand that you have 2 issues.
1. Stuck in offline mode and can’t save the model
This is an article which Fusion 360 is stuck in offline mode. Would you mind trying this?
If it didn’t work, could you change location of Temp folder from %Temp% to C:/Temp? this is how to change it.
Do you have a specific name on your PC account
2. Graphic issue
Unfortunately, Fusion 360 is supporting only CPU. I found the best answer in our Forum. hopefully, this will help.
I look forward to your reply.
Have a great day! Heart
Many thanks,
Ahreum.
