Hello, while modeling a surface, I ran into a bug related to 'Split body' and wanted to share it.
I drew a symmetrical spline to split a surface.
Then, I created a sketch on the XY plane and drew a line, and mirrored it to make an isosceles triangle profile.
Although I drew all the sketches symmetrically there was no profile created. I found that there was a 0.001mm gap between the end of the mirrored line and the intersected point. However, when the process was done the same way with the other surface with the identical boundary edge, everything was fine.
The problem seems to happen randomly because after moving the timeline backward and forward to double-check all the sketches I made, redrawing the last sketch sometimes made a profile normally.
Hope this will be fixed soon. thank you.
Solved by TrippyLighting. Go to Solution.
Solved by TheCADWhisperer. Go to Solution.
Are you sure that you want to Mirror a Spline?
This is my curvature display...
See Attached file...
I generally is not a good ide to work with mirrored fit point spines in Fusion 360. Scaliing of angent handles is partticular to an individual spline and they might start out symmetrical, but editing one will not nevessarily result in a symmericval mirror.
For the surface split in sketch63 as suggested by @TheCADWhisperer I'd use a closed fit pooint spline.
For the curve in sketch64 I'd start with a 3-degree control point spline with 4 points and see if that is enough to reprresent the curve in the canvas.
Control point splines can be mirrored without problems.
Thank you for the image and the file you attached. It helped a lot. I now clearly understand the difference!
Thank you so much for the detailed explanation. I really appericiate your reply, thank you!
