Surface Modeling | Patch Command Not Working in Certain Situations
Message 1 of 9
I've run into the same issue every time I use  surface modeling in fusion 360 where it doesn't view a 3D sketch as a complete surface and I therefore cant use the patch command. I have attached photos of the most basic issue I have with it. It wont let me patch the surface even though all points or coincident unless I draw a simple 2D line to connect the triangle.
Replies (8)
Message 2 of 9
jhackney1972
The Surface Patch tool is a 2D command so it will not generate the 3D patch as you can see.  You will have to use a surface loft on conical surface extrude and trim it.
John Hackney, Retired
Message 3 of 9
jhackney1972
Here is an example of a conical surface section like I think you want.  It was done with a surface loft.
Message 4 of 9
The patch command definitely works with 3d sketches. Not sure what I'm doing wrong in the other situation.
Message 5 of 9
jhackney1972
I apologize, it does work but it is not a very good patch.  I prefer the loft surface.
Message 6 of 9
jhackney1972
You can improve it with an added rail.
Message 7 of 9
jhackney1972
If you still are having trouble, post your file and the forum users can take a look for you.
Message 8 of 9
Most of the webinars on surface modeling include 3D sketches being patched like this.
Message 9 of 9
I think I've figured out a way to get the desired effect with the patch command. Thanks for your quick replies and alternatives.
