Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Super Slow Performance, regardless of complexity of design.
5 REPLIES 5
752 Views, 5 Replies
I'm running a PC that should have no issue keeping up with fusion; however, even drawing simple shapes causes a lag of input. This is causing it to take forever to model anything. Any help is appreciated! I've posted the Graphics Diagnostic info below.  Thanks for any bits that can improve this for me.
AMD Ryzen 5 3600 CPU
32GB Ram - 3200
64 Bit Windows 10
[GPU Information]
GPU Device: AMD Radeon RX 5700 XT
GPU RAM: 8192 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 27.20.12029.1000
GPU Driver Date: 09/16/2020
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
5 REPLIES 5
HughesTooling
Someone in another thread suggested setting the graphics driver to DX9 helped.
If that doesn't help could you make a screencast of what you're seeing?
Mark
Mark Hughes
Owner, Hughes Tooling
in reply to: HughesTooling
https://autode.sk/2RFf8UC
no change after DX9... hope this screencast helps
**I'll work on getting a screencast that works on my lunch break** but just drawing a box, it takes 3 seconds between allowing me to draw lines
HughesTooling
That doesn't look good! Only time I've seen something like that before was when someone deleted all their projects and designs from the cloud, have you got designs saved to the cloud?
Mark
Mark Hughes
Yes, all designs are uploaded to the cloud. No concerns there. Had a co-owner log in from his laptop and pull files and edit without issue. Definitely something on my PC. Nothing else on my PC is struggling. Games, Inkscape, etc... all fine.
https://autode.sk/32NLao6
Dug a bit deeper and found that Fusion was running in compatibility mode for Windows 8...not sure how/why that setting ever got enabled.....removed that, and boom!~It works again!.
