Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Subscription expired read only
5 REPLIES 5
rdengineering66
1314 Views, 5 Replies
Just opened Fusion and I get the following.
When I click OK Fusion opens  but this is what I see. Says subscription expired read only.
 My subscription does not expire until Jan 2022 as can be seen by the screenshot from my account page.
Any idea what the problem is? I have tried logging out, closing Fusion and then restarting and logging in but just get the same.
5 REPLIES 5
Thanks for using Fusion. Sorry for the inconvenience.
Can you check in the web interface, if you have got the right entitlement seen in the web interface? You should not have a "basic access" banner on top. This will ensure if the entitlement is incorrect or if the build you had was corrupted.
If you are seeing the proper entitlement, then please try uninstalling Fusion and install back again to get this issue resolved.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
Thanks, the uninstall/reinstall worked.
Good that the issue is resolved for you. Happy designing!!!
 Sasikanth Kollipara
LinkedIn
Same error here on a brand new laptop, brand new licence. Uninstall/reinstall has not fixed it.
calebsalexander
in reply to: ackoons
Same problem with the new install but uninstalling also doesn't work.
