Subscription expired read only
rdengineering66
rdengineering66
Just opened Fusion and I get the following.
When I click OK Fusion opens  but this is what I see. Says subscription expired read only.
 My subscription does not expire until Jan 2022 as can be seen by the screenshot from my account page.
Any idea what the problem is? I have tried logging out, closing Fusion and then restarting and logging in but just get the same.
sasikanth.kollipara
Thanks for using Fusion. Sorry for the inconvenience.
Can you check in the web interface, if you have got the right entitlement seen in the web interface? You should not have a "basic access" banner on top. This will ensure if the entitlement is incorrect or if the build you had was corrupted.
If you are seeing the proper entitlement, then please try uninstalling Fusion and install back again to get this issue resolved.
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Sasi
 Sasikanth Kollipara
 Sr. Quality Engineer in Fusion
LinkedIn
rdengineering66
Thanks, the uninstall/reinstall worked.
sasikanth.kollipara
Good that the issue is resolved for you. Happy designing!!!
 Sasikanth Kollipara
LinkedIn
ackoons
Community Visitor
Community Visitor
Same error here on a brand new laptop, brand new licence. Uninstall/reinstall has not fixed it.
calebsalexander
Observer
Observer
Same problem with the new install but uninstalling also doesn't work.
