I'm trying to save this file it was the word mom with the "o" being a gimball. My dad asked if i could make it say oscar for his coworker.
So i imported it, then cut away the "m's" and added the scar to the end. and when i try to save the whole thing it won't let me, so i tried saving it one at a time then assembling it later. but it says these to error messages.
"Error: Autodesk Translation Services failed to translate the current document to stl file!"
And
"Error: STL Translator failed to export data"
any ideas
Hi @Anonymous,
Thank you for posting!
Could you share your design? Here is how to share it. (ahreum.ryu@autodesk.com) . I tried with a simple model and it seems to work. so I would like to look into your model.
This thread may help.
I look forward to your reply
Many thanks,
I'm having similar (maybe the same) issue. If I try to "Make", it fails the first time. I have to run the Make command a second time and then it's able to move the design into my slicer software (Cura 3.1.0). Screenshots attached.
Hi @Brady_Fulton,
I'm sorry you are experiencing this issue. Could you share your design? Here is how to share it. (ahreum.ryu@autodesk.com)
Many thanks,
Ahreum.
This is great when I clicked the link to test it I saw a download button and clicked and it worked.
If you have an idea on how to prevent this I'm all ears.
Hi @Wingedthing0,
Thank you for sharing!
In my laptop, it's working, Could you take a look at my steps?
I tested it on Mac, Win7, Win10 and it seems to be ok. Could you check Fusion 360 is installed by up to date (2.0.3800)?
Many thanks,
Ahreum.
Restarted computer this morning. Opened up Fusion 360 and was notified that there was an update pending a restart of the software. Did that and haven't seen the issue yet today. Thank you for your response.
